I'll presume you have no "fault code" appear in the display, i.e. F30, F31 correct ? Is it both top and lower oven ? What happens when you select a bake cycle, anything ? Does it appear to be on, but no heat ?
Just need some clarification and details and I'll try to help.
Is that the case with both the upper and lower ovens though ?
If so, do you hear the cooling fans come on ?
These are equipped with "sail" switches that can become crushed/bent or obstructed during installation/service or just dirty from their environment.
Let me know, (I know it may seem like redundant questioning, but it is necessary from afar to be thorough)
Mark
Well from that description I'd be looking at a possible bake relay on the board since there isn't even a fan coming on. Typically the fan comes on activates the sail switch, and lastly the bake element is energized. It would likely be worth while getting a appliance tech on site, preferably an authorized b/s/h (thermador) person as these can be difficult to diagnos if one isn't familiar with them. Sorry I couldn't be more help, it's one of the on-line limitations. :(
let me know if I can help in the future.
Good Luck :)
If it turns out to be your control board, we could fix it for you.
www.fixyourboard.com
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
it appears to be on, but no heat.
the top is microwave, botton is oven, broil is working fine.
You can hear only clicks when turn bake on, but no cooling
fan or heat ay all.
Thanks....
thanks a lot
