Compaq Presario CQ60-220US PC Laptop Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My labtop is working, but it is low on battery. I
My labtop is working, but it is low on battery. I have it plugged in, but it does not say "charging." So, I am losign battery quickly, as the labtop is not recognizing that it is charging. What can i do to solve this issue?
Clive Gray
Level 3:
Genius:
  • Compaq Master 1,479 Answers
  • Posted on Oct 29, 2009
Clive Gray
Compaq Master
Level 3:
Genius:
Answers
1479
Questions
Helped
291038
Points
4728
Either the power block or battery is faulty. remove battery and see if it will run directly off the power block, if not, you need a new power block.
How can i reboot my labtop
Best way that works for me is to unplug your wall adapter, turn the unit over, and remove the battery for about five minutes.
This allows the laptop to fully de-energize and restart after replacing the battery and plugging the adapter back in.
Screen goes into different colors when i turn my labtop on nothing else
Take out battery & AC adapter plug. Wait 10 minutes.
Plug in AC adapter without the battery. Power on the laptop. If it works, put in the battery when laptop is running.
1helpful
I have toshiba M500 (6-celled battery)as the dealer person told that my laptop will give a minumum backup of 3 hrs but i can't get this much only 2 hrs is given why and is there any problem with my...
No there is no problem in your labtop or your labtop battery.
The life or the time of battery back up depends to what you work in your labtop.
So if you listen to music or watch videos the time of battery backup will be short because listening
to music or watching some videos uses much power to supply the devices of multimedia like the
labtop speakers and the hard drive motor ,in addition to the labtop FAN
All those devices needs more power to run .
But if you dont work in your labtop on any of these are membered and just surf the net or work
in other places the battery backup time will be longer.
2answers
Yesterday my battery was low so i plugged my netbook in. the battery light wouldnt come on, and when it did it just flashed. the netbook will not charge.
Check the cable of the charger then check the connections parts between the charger and between the labtop
they might be damagged
I Dell Labtop is not turning on. 3 lights blink continuously
do you still have your battery working? if not, you may have a problem with the adapter. could be a partial contact from the main adapter or at the charging port on your laptop. use a tester and check for continuity on the adapter cable and also check the power output going into the laptop.
1helpful
2answers
Unable to boot dell inspiron 1525 labtop
get a new battery and try that but check your power supply before you plug it in. Most laptops will work directly off power supply even with no battery present. If these solutions don't work for you then you need professional technicians help or a decent bin.
No power
The laptop should power up with the AC Adapter plugged in, if it works, and you want to be mobile, buy the battery pack for it. Battery's sell for around $75 in some places on-line.
Have a nice day!
3answers
I wana increase the sounds of my toshiba labtop
The only way you can get it to go louder is to add amplified speakers to it. They usually aren't designed with a lot of wattage to them to save on battery life.
If you really want it loud, you can get a Y audio cable with a mini stereo plug in one end and rca jacks on the other end and find a stereo receiver to plug it into.
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
