American Standard 2771.002.021 Cadet 5' x 36" Bathtub, Bone Logo
Posted on Oct 29, 2009
We are an electrical contractor. A client asked
We are an electrical contractor. A client asked us to figure out what is going on with their Mansfield jacuzzi tub. The power to the unit is fine. The unit works fine. But, every so often, the jets randomly come on for a little while. We are wondering if they are just sensing water in the jets and are clearing them out? Any thoughts
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
24048
Points
20
There arn't any provisions for ejecting water out of the pumps that i know of. The pipes are installed on the tub so that they will gravity drain back into tub. The pump wouldn't be able to run unless fully submersed in water above the jets, i mean it will but not for long. I would sugest disconnecting elec. to pump until you resolve the issue or else the pump will burn.
-This sounds like some kind of air switch problem. Something is causing the air switch to sense the air pressure excerted through the air hose without the button being pushed. This is the only thing it really could be since the power to the pump goes through this switch. I cant imagine anything else causing this other than a faulty air switch on the pump itself. This would mean the pump would need to be replaced since the air switch is sealed in place at factory. Unless some how, some way, air pressure is increasing in the air hose all by itself, not likely. But check the air hose connections on the pump and the button on the tub, if you can even see it. The hose may be partially attached and any slight movement while partially attached could push air into the switch but thats kind of a long shot. I dont know if a craked or split air hose could cause this to happen but i guess its possible.
-If i had to bet on it i would definatly say the pump switch is defective.
Good luck!.............T.Wood CFE Plumbing
tip
How To Avoid A Roofing Disaster
Here are the top guidelines for picking a roofing contractor and avoiding a
DISASTER.
1. Along with the quoted price, ask for references, ask about any current jobs they're doing and then drive by those jobs.
* There's a BIG variation in the professionalism among contractors so you want to find that sweet spot between price and quality of work.
2. If the site is an total pigsty; plants trampled, stuff strewn around, etc, you might not want them on your property.
* Your property should look like it did before they showed up, only with a new roof.
3. They should also give a warranty for roof leaks.
* If it rains, and you have a leak they should be there within a reasonable time.
4. Ask for proof of insurance. They must be insured & bonded
5. Ask the contractor how they will protect the landscaping.
* Most will make an agreement that any damage will come out of the final payment.
6. The contract should specify the materials used, a time-line for completion, and how payment will made & scheduled.
7. Make sure the contractor is insured and, if his employees will have access to your house, that they are bonded.
8. Once again, get references from the contractor.
* And check them.
9. Hire a roofing contractor that has a reputation in the community.
* Check with a local builder and ask who they recommend.
10. You can also use someone you know and trust even if they have a small company.
Integrity Roofing & Construction has been serving the Northwest Ohio areas since 2000. We take great pride in our work and offer our
clients 1st class remodeling.
Our goal is to give the best price possible without using inferior products or cutting corners in workmanship just to lower the cost.
Not only do we use the most proven and up to date products in the industry, we also offer some of the best and longest warranties that the market has to offer.
The most important part of our job is your complete satisfaction. We want you to enjoy working with us from the beginning to the end, and therefore, will do everything in our power to make that possible.
We strive to serve our customers with integrity and professionalism.
5answers
How could i know whether my contractor is reliable or not ?
You first make sure your contractor has a few jobs under his belt.Ask their clients for a testimonial about them.Also make sure he completed his previous projects well.Now a days there are many Review websites which gives the info about the ratings of the home renovation contractors and home builders. You could check there too.
Hello sir,I wan a AC for the 150 sft office.how much tone AC required for this much big room and wat wil be the cost of it.
the tonnage is found by taking the wattage of all equiment in the room to include the lighting utilising a formula to equate to btus. take this run a t-24 calc figuring all the factors window r factor, insullation, shading roof compasition, room facing direction etc. what system are you wishing a ductless split? motel unit? bard? split? heat pump? room unit? also electrical needs to be ran. figure a $1000 per ton contractor installed plus the electrical $500-750.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
