NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" There may be a hard disk problem. Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the hard drive and also where it connects to the motherboard. If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
try other good known hard disk install it on your server, if it detect the presence of that disk then your hard disk previously installed has the problem, it going to be defective sooner or already defective
If so you need to enter the RAID config (not the bios, but there will be a RAID config option during the boot process CTRL+M I believe.. but it will say on screen.) Then you need to set up the raid config, then initialise, then the drive will be detected for loading the OS.
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Try taking the side off and removing and replacing all the hard drive leads. Remove and replace all the scsi drives and generally check for loose connections. If this does not work you will need to post more infomation.
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence
The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
Onboard or USB floppy drive
Onboard SATA hard disk drive
Onboard IDE hard disk drive
Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
Onboard or USB CD-ROM drive
Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
