I have a 1989 dodge dakota and my radio wont turn on after the cap for a relay fell off and i went to put it back on and it sparked and the radio shut off. please help me. ive checked the fuses and theyre fine. i even replaced that relay. everything but the radio works. the light for the radio wont come on and when i start it up the speakers thump.
? 8:10
https://www.youtube.com/watch?v=a-rfAd0YLg0
Jun 29, 2014 - Uploaded by AJ Pierce
In this video, I will show you how I fixed my 1992 Dodge Dakotanot starting. ... Engine cranks but won't start - Duration: 18:30. jimthecarguy ...
Engine Will Not Start Due to Blown Door Lock Fuse on Dodge Dakota ... cap and rotor, wires, plugs, coil, fuel pump assy, coil pickup sensor, crank position sensor and have new ECM on the way, Cranks but won't fire. ... 1990 Dodge Dakota.
Jan 22, 2009 - have a 1993 dodge dakota sport that wont start. when you turn the key on there is no power to the fuel pump and does not fire. any ideas ... I just bought a1990 Dodge Dakota Sport 4x4 5-Speed, there is only one problem, it only .... I went to move it the other day, it would turn over, but had no spark or gas.
If a vehicle won't start, it's one of two things: no spark, or no fuel. If the vehicle is turning over, you can check for bad coils, distributor cap/points, or bad spark plugs/wires. On the other end, you can check for clogged fuel injectors/carburetor, clogged fuel filter, etc.
check and make sure you have 12 volts to fuel pump with key in on position, if not trace back wires to relay if good, turn key on, off , on, off then leave on and check codes may be crank sensor, or cam sensor
u have put new coil and no spark in plug , it is ur distributor cap is needed replacement but first have a look inside the distrubutor cap for any wear if is u need new one ok
