Step 1: Find a song on YouTube or other streaming platforms.
Step 2: Use audio recorder to record the song from YouTube. Here Leawo Music Recorder will be recommended: https://www.leawo.org/music-recorder/?fixya=1409. Save the recording into MP3 format.
Step 3: Import the song to iTunes, and you should convert the MP3 to AAC or at least make sure the music file has an .m4r extension. You can simply add the sound file to iTunes and then you can find it in your library. Then select the loaded sound file in iTunes and click File >> Convert >> Create AAC Version. Wait for some seconds, the MP3 would be converted to AAC format.
Step 4: Once you have converted the MP3 to AAC ringtone format, you can find two song files in your iTunes library. Next, right click on the AAC file and you can rename and change the file extension to .m4r.
Step 5: Add the ringtone to your iPhone with iTunes or other third-party transfer tools.
You can make ringtones from your audio recordings. Simply edit the audio file using RecordForAll http://www.recordforall.com . Then connect your phone to your PC using a USB cable and transfer the file to your phone.
Goto My Stuff Menu-> Audio & Ringtones -> Record Voice.
You can record your own audio by tapping the center [OK] key. The recorded audio file is saved automatically in the Audio&Ringtones.
Quality: Determines the quality of an audio clip.
Record Mode: Sets the recording mode to either MMS or General.
Primary Storage: You can set the primary storage of the recorded audio to the Handset Memory or the memory
Card
After your sound recording, go to your record folder and then open the recorded sound and then option and set it as a ring tone.
SOURCE: Can you make a voice recording into a ring tone lg cu500v?
I found a few sites that offer that program"
http://cellphones.about.com/library/bl-so-ca-lg-ringtone-maker-software.htm
http://www.mrbass.org/ringtones/
I understand that you need a special cable to connect to your computer so you can load them on.
SOURCE: How do I record something
puezz puedezzz cortar una kanciion iii tiiiene ke durar por lo menozzz 29 segundoz ojala te sirva el aporte
