I just bought a Ford Mondeo Ghia 1.8 1996 model, station wagon. Old car, but in good shape.
Almost embarrased to ask, but I only find the fusebox under the hood.
I think there should be another one. But I cant find it.
Have checked in glove box, under the dash on both sides. No luck.
Help.
Regards,
Roald
Norway.
gain entry press both sides of the glovebox when open and it should drop down to reviel the internal fusebox gain entry press both sides of the glovebox when open and it should drop down to reviel the internal fusebox
You can't post conmments that contain an email address.
I have a couple questions my radio in my Ford Mondeo Ghia 1998 V6 duratec engine 2.5L won't play anything I checked fuse behind glovebox it was all good is there other fuses I need to check instead of taking every single one out to check them.
My left tail light is letting water in the trunk/boot I have tried to silicone repair it without bonding it to the body but still water is getting in behind the two tail light bolts on the high side of the light and a puddle in the lowest part of the tail light itself any tips tricks or ways to fix without bonding to the body
drive into a ford garage and ask then if they can find the pass code for you vehicle may cost a bit depending on the garage so wold ring around first. if it is the original radio there systerm will have the code.
I have ford mondeo ghia 2002.
when i press the button on the remote-key, I can lock and unlock the powerlock (in the door).
When I press the button un the door, not all doors are locked.
if your fusebox is in the panel to the right of the ignition key, the fuse is number 29, this fuse also covers other items so it maybe that either the cables have come off the back of the lighter or it is faulty if the fuse is good. hope this helps.
