I need to open my NetGear router ports to access playstation home. When I try to connect it times out so I have been told to open the router ports and that will fix it. I have all the info for the ports and gateways, etc, I just don't know what to do with it. I also have to create a static IP address. Just one more thing I don't know how to do. so if you can help me I will be very grateful.
Here are the steps to open ports for your playstation:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5.Click on Advance settings (under setup) and choose port forwarding
6, Add a new port address,port number etc (It is the address of your Playstation and the port to be opened)...
The most common of these are TCP and UDP ports which are used to exchange data between computers and the Internet.
In order to use some games and features on PlayStation Network the following ports should be opened:
TCP: 80, 443, 5223, and Port Range 10070 - 10080
UDP: 3478, 3479, 3658, and 10070
This is how the port can be opened, for more information please refer the following link given below..
http://kbserver.netgear.com/kb_web_files/n101145.asp
PORT OPENING
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Hi: Just to let you know. I went to the Playstation PS3 website and logged in so I could tell them what an annoying, frustrating experience this has been; I wanted to give them the correct error code so I went through the motions of logging onto their Playstation Home site, and you're not going to believe it, but it worked! I was stunned! After all the messing around trying to find the right instructions and the right program to open the ports...and there it was. So, for whatever reason, it is fixed. I would like to thank you for your efforts and your expertise. I appreciate the help and advice. Take care. All the best, Sharon Long
