The tv has power,because the red light in the front center bottom is on and i think its suppose to be green,but the screen will not come on.is there a re-set button some where? or did some component fail?
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty.
did you check those fuses again after you powered it back up?
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
i have an alinemenet problem with my rca tv P52929 i went to the book and it said to go to the menu and select 3 which is the screen menu then select option 6 which is the adjust projection tv. this is suppose to allow you to adjust the the tv's three colors. it says to select the green centering to adjust the green tube. blue for the blue and red for the red. it says to center the green first then adjust the red and blue tubes until the test pattern on the tv screen appears white. i hope this helps you. my problem is that the program is not in my tv. it has everything else but not the option 6 to adjust the tv. this may be your problem to. good luck.
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
