What happens when you attempt to download? (Try this without the memopry card in?)What happens when you attempt to download? (Try this without the memopry card in?)
You can't post conmments that contain an email address.
The battery life is quoted as 250-350 pictures in auto mode. This would be for a new battery and camera and it is likely that the number of recharging cycles on a 7 year life will have led to some deterioration in the battery life. The two links below take you to pages from which you can download the Users guide and getting started guide in a pdf format. http://www.manualslib.com/download/348740/Kodak-M753.html
You can view one online and/or download a PDF version from the manufacturer's web site at http://www.kodak.com/global/en/service/products/ekn032925.jhtml?pq-path=11250
It appears that your problem lies with the main board their are two small fuses on the main board that can cause this problem. changing the main board is most likey your best bet repair on this can be around 65.00 and up depending on where you get it fixed.
Unless you have a spare battery and/or external charger it will be hard to tell if the charging circuit is defective or the battery is bad. I have seen posts in other forums with the same issue. I assume the camera is under warranty but you may want to purchase a spare battery and charger anyway as a backup if you are going to keep it.
you mean a kodak m753? i have one they should just download liek a picture, except it will be a video. just plug it into your computer, and if that doesn't work maybe you're looking for it in the wrong place.
