Anonymous Posted on Oct 28, 2009
How to get non-hd DD or DTS sound from blue-ray on old receivers
How to get Dolby Digital and DTS surround sound on older receivers with hd audio tracks from blue-ray players using s/pdif connection?
I have an Onkyo TX-DS 595 and have just bought a Swedx Camo 46'' LCD (SG-46X5-A2). I would like to get a blue-ray player but I haven't really found the info I need about what kind of audio options I will get with the Onkyo using digital connection (s/pdif coax or optical).
What I know: If I connect the blue-ray player using coaxial or optical , there will be no hd audio transmitted. Since both Dolby Digital and DTS hd audio formats are backward compatible you should be able to get regular DD or DTS surround under certain circumstances. So the question is, what features do you have to look for in a blue-ray player to get it to send an old receiver non-hd DD or DTS surround sound even if the disc only contains for example DTS HD Master Audio sound?
mikelpoynter
Level 2:
Sniper:
  • Expert 77 Answers
  • Posted on Oct 29, 2009
mikelpoynter
Expert
Level 2:
Sniper:
Answers
77
Questions
Helped
23293
Points
283
It is not necessarily what features you have to look for, it is what connections you need to look for. Most blu ray players have the hdmi ports. On my blue ray I found it and it has the fiber optic end. I have used that and to me it sound just as good.
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
1helpful
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
2answers
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
1helpful
3answers
Dolby digital
Dolby Digital includes several similar technologies, which include Dolby Digital, Dolby Digital EX, Dolby Digital Live, Dolby Digital Surround EX, Dolby Digital Plus, and Dolby TrueHD.
Dolby Digital, or AC-3, is the common version containing up to six discrete channels of sound. The most elaborate mode in common usage involves five channels for normal-range speakers (20 Hz – 20,000 Hz) (right front, center, left front, right rear and left rear) and one channel (20 Hz – 120 Hz allotted audio) for the subwoofer driven low-frequency effects. Mono and stereo modes are also supported. AC-3 supports audio sample-rates up to 48 kHz. Batman Returns was the first film to use Dolby Digital technology when it premiered in theaters in Summer 1992. The Laserdisc version of Clear and Present Danger featured the first Home theater Dolby Digital mix in 1995.
This codec has several aliases, which are different names for the same codec:
* Dolby Digital (promotional name, not accepted by the ATSC)
* DD (an abbreviation of above, often combined with channel count: DD 5.1)
* Dolby Surround AC-3 Digital (second promotional name, as seen on early film releases and on home audio equipment until about 1995/1996)
* Dolby Stereo Digital (first promotional name, as seen on early releases, also seen on True Lies LaserDisc)
* Dolby SR-Digital (when the recording incorporates a Dolby SR-format recording for compatibility)
* SR-D (an abbreviation of above)
* Audio Coding 3 (relates to the bitstream format of Dolby Digital)
* AC-3 (an abbreviation of above)
* Audio Codec 3, Advanced Codec 3, Acoustic Coder 3 (These are backronyms. However, Adaptive Transform Acoustic Coding 3, or ATRAC3, is a separate format developed by Sony)
* ATSC A/52 (name of the standard, current version is A/52 Rev. B)
Different Audio options from an older receiver
If your receiver has a multichannel input and the player has the multchannel output then that is the only way you can get surround sound from it with source inputs that it cannot decode, such as DTS. The player will then do it alone.
However, in the setup menu of the blu ray player you should be able to change the audio output to downmix to 2ch audio...at least you'll get to watch the movie.
1helpful
3answers
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Display while playing movies
Hi, no, this is not the normal display. It should indicate the digital sound format like DD or DTS, etc. If it is displaying PCM, this is probably due to the audio settings on your DVD player. Please provide your DVD make and model, and I will look to find the solution.
1helpful
2answers
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
2answers
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
 Grubhead
Grubhead
SmartAviator
SmartAviator
