Samsung RS265LBBP Side by Side Refrigerator Logo
Posted on Oct 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fridge temperature display of my samsung rs265lbbp twin cooling is flashing and the fridge is low cooling but the freezer is doing good. what is the cause ans solution to this?
Mark Whalen
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 27, 2014
Mark Whalen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1376
Points
My fridge has started to drip water the ice box I have taken out but the food is defrosted it is a Samsung RS21DGRS the freezer temperature is only reading any ideas please
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Oct 28, 2009
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
910830
Points
7895
Its likley to be the thermostat packed up on you, the only fix is a new thermostat fitted,,,
Samsung RT18M fridge off light flashing?
Pull the plug out, count to 20 and plug it back in as a start. Lots of help here
Samsung refrigerator temperature display is blinking
Samsung US https://www.samsung.com > support > TSG01002092
A blinking temperature display is trying to get your attention, typically because the temperature is too high and things need to cool down.
Samsung Refrigerator Temperature Display Is Blinking
Samsung US http://support-cacyber.samsung.com > popup > iframe
The temperature display or temperature bar on your fridge will blink if the temperature inside the fridge is above 59 degrees Fahrenheit. It will automatically ...
Missing: RT18M ‎' Show results with: RT18M
Why Your Samsung Refrigerator Display is Blinking
appliancegeeked.com https://www.appliancegeeked.com > how-to-fix-samsu...
Dec 21, 2022 - A blinking temperature display on your Samsung fridge suggests a temperature error. The most common cause for this is warm air trapped inside ...
We just bought Samsung Refrigerator RT18M"/RT21M and ...
JustAnswer https://www.justanswer.com > Appliance Repair
Sep 23, 2022 - The freezer display lights are blinking. There's recently a · The freezer display lights are blinking. There's recently a thin layer of ice on ...
1 answer · Top answer: Hello, my name is*****'m here to assist you today, can you provide a model number..
Freezer is fine. fridge side does not get cold
Samsung sxs refrigerators usually have a dual cooling system. That's why the freezer works fine. Refrigerator side could have a clogged drain or a defrost problem.
Samsung fridge coils frozen over on refrigerator side.
Not sure what the ohms should be,but ckeck coils for damage you may have a leak
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
The freezer works fine, but the frige side is not cold at all. the unit is still under warranty, and the service guy replaced the "control board". but that worked for about a week. Everything is...
Hello Patrickbono,
I understand that your are having a problem with your fridge it is not getting cold. However, the freezer is cooling just fine this is a common occurrence when the evaporator fan goes out in the unit. Here is a tip you can follow to help you diagnosis the problem
Fridge not getting cold?
I would suggest you call the service tech as the unit is still under warranty and have them to replace the fan and check the rest of the unit.
Thank you for choosing FixYa.com
justinbur167
Fan blowing air across coils, compressor seems to be working. refrigerator portion not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
2helpful
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
5helpful
2answers
Fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
