When connected just keeps searching
Problem is solved On the telephone headset to make the first reset, selecting keys 1 0 and confirm the green headset. After that, the BASE press for registration until the hear a beep. Within 30 seconds the phone headset press PROGRAM 1 6 and enter the number 20,000 and confirm the green headset, or OK. Telephone handset is registered as the second in a row and at the same writes h2 n2. Problem solved PROBLEM JE RIJEEN Na telefonskoj slualici prvo izvriti resetovanje, odabirom tipki 1 0 i potvrditi zelenom slualicom. Nakon toga na BAZI pritisnuti tipku za registraciju dok se ne čuje BIP. U roku od 30 sekundi na telefonskoj slualici pritisnuti PROGRAM 1 6 i ukucati broj 20000 i potvrditi zelenom slualicom, odnosno OK. Telefonsk slualica registrovana kao druga u nizu i na istoj pie h2 n2. Problem rijeen
SUCCESS! Problem with my binanotone 3300 is resolved. Note that the defect was reflected in the fact that the display of telephone headsets hb without showing any mark that is constantly flicker. The way that I remove the defect is as follows: pristisnuti PROGRAM 1 0 and confirm the green headset that tvornične reset the settings, the central unit of the phone-BASE-press registration, keep the key press until you hear a beep, then within 30 seconds to type program, and 1 6, then the tag headset phone with me has been the case that this is the second receiver, so I pressed the number 2, then press četiti zero 0000 and confirm the green headset.
