I have a Vista 64 bit OS and can't get my midi driver to work with it. I have a Midiman 1x1. What do I need to buy that will work with a 64 bit Vista OS? Casey
Supported Operating Systems and HardwareMQ Essen
tialsMidi
QuestMidi
Quest
ProInfo32-bit Windows support: Win 8, Win 7, Vista, XP64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts
Intel Macintosh systems: OS X 10.9,10.8, 10.7, 10.6 and 10.5
Most of the device and their driversare compatible with Windows Vista if they support XP.Still if the drive isn’t supported go to theofficial website of the hardware manufacturer and look for the drivers. Thesedrivers are generally free of cost.
You need a 64 bit driver for your sound card so that you can install it in windows vista 64 bit operating platform. Visit the product website and obtain the 64 bit version of its driver for windows vista.
Hi there just because it says it has not passed the windows logo check does not mean it will not work. It only means it has not been tested by microsoft. Set a system restore point first then install it and see if works. If any problems you can always restore your computer back to how it was.
Please dont forget to rate me.........thanks from Scott
Very often you will find that not much older periferials like Cameras, Printers, Ipods, Scanners, and many Applications do NOT work with VISTA 64 Bit O.S..
First go to the CAMERA MANUFACTURER Customer Services or Website and see if they have a PATCH or another Driver for this camera so it can operate on VISTA 64 Bit. If it does, simply DOWNLOAD THE DRIVER AND "RUN" it and it will replace to old driver and your Camera will Run Properly,
If there is no Driver offered to run on 64 bit program then you have more serious issues that require more radical fixes which you have to evaluate on the basis of how much you need the Periferial or can there be a substitute that can run on the 64 bit program. 64 Bit programs are basically not much different from the much more popular 32 Bit Programs your camera would probably work on, no problem.
Try Calling Microsoft Customer Service and/or look on their Home Page for Solutions but generally the only alternative is:
1) Return the Camera and Exchange for one that runs on Vista 64 bit O.S.
2) Downgrade your Computer to a 32 Bit Version of Vista.
3) Look for the latest Beta Solutions you usually find on Google that may fix this
Vista 64 Bit O.S. Versions are only necessary if you are using more than 4 GB of RAM for e.g. GAMMERS who require a lot of Memory (actually up to 128 GB). Otherwise there is little difference between 32 and 64 bit versions. As VISTA was not that popular to begin with, many manufacturers did not bother providing UPGRADED SOFTWARE AND DRIVERS for VISTA 64 BIT assuming few would buy it off the shelf and mostly their product would be used with WIn XP or Vista 32 Bit until the Next Microsoft O.S. Came around.
Vista is a Memory Hog and as such should be used with only 4 GB of RAM for it to run properly. 3 is adequate, 2 GB its lethargic at best. VISTA 32 bit HAS A LIMIT OF 4 GB of RAM so that is cutting it close but still a better idea to "DOWNGRADE" to 32 Bit so your O.S. would be much more compatable with other Periferals and Software Applications. Many Periferals ( appliances) and Applictions will not run on 64 bit programs especially if they were designed before 64 bit was introduced. THE BEST FIX, IF YOU ARE NOT A RAD GAMMER REQUIRING MORE THAN 4 GB OF RAM is to "DOWNGRADE" TO VISTA 32 bit or even better to Windows XP if your computer can work with that O.S.: check with the Manufacturer. Your camera may even work on XP 64 bit.
Kodak still makes some nice disposable Film Cameras; you can take your pictures then have them developed, and scan them into your computer that is if your SCANNER STILL WORKS with the 64 bit program LOL
Ummmm. Its quite expensive to do that but i suppose if you need to ten its a viable option. You could buy a cheap 32 bit machine instead or try downgrading vista.http://www.microsoft.com/windowsvista/1033/ordermedia/default.mspx
This may help you if you retail bought the machine.
