It is common for these valves to "appear" to be ok, meaning they begin to allow water into the unit, but then one of the two coils or plungers inside fail, or are clogged with mineral deposit from the water or other debris.
Change the valve and you should be fine. part #1164471, you can find it at select parts depots or on-line retailers like repairclinic.com etc.
** Hire a pro or make sure to use a good replacement clamp on the fill line to the tub when you replace the valve, as well as some plumbers puddy/tape on the inlet fitting. Those little buggers have alot of water pressure going thru them when they open and I've seen them come off or leak due to insufficient fastening/loose clamps, then your machine goes into "flood mode".**
Asko seems to be repeating their past. On the earlier DW95 series (mid 90's to around 2000ish) they had a dual valve inlet which had a single valve rework issued to repair the faulty dual valves, now it looks like they're doing it again. Go figure.
Hope that helps, let me know.
Good Luck :)
All im going to say is i think you have a faulty inlet valve.the water is probably only trickling into the machine & taking forever to fill,the computer board has probably picked up that the washer is taking to long to fill & has thrown up a fault code relating to the fill or inlet valve.Also sometimes if the filters in the bottom are clogged the water cant get to the wash motor & the motor cant load up with water.The motor runs without load on it & the computer board interprets this as slow fill or inlet valve problem.
