Question about JBL HLS810 Main / Stereo Speaker
The woofer doesnt work think its blown is it fixable
    Problem Solver:
  • 14 Answers
First, unplug the stereo speaker then open the back. you see the 2 wires attached to the woofer then test it by multi tester. if it moved it means its okay. check the wires for the loosen speakers. solder it and test it.
Posted on Oct 28, 2009
SOURCE:
2009 Jeep Sahara sub woofer not working
if the wires are connected then you ether have a blown amp or sub. try hooking up a diff speaker to the wires if it works your sub is blown. if it doesnt your amp is blown
Mar 13, 2013 | Audio Players & Recorders
Have Acoustimass 15 system. Subwoofer stopped working and I don't think the fuse is blown. Anyway it does not look blown.
OK - well "look" blown may not be a solid, engineering approved, check. You could take the fuse down to a local Radio Shack and have them test it. Good news is that they will probably have a replacement if you need it. OTHERWISE... Keeping the volume WAY down - you can try another speaker on that output. It doesn't really have to be a woofer, just something to verify the circuit is working. That should tell you if the pathway is good which then tells you if its the woofer or the amp/receiver.
Oct 26, 2010 | Audio Players & Recorders
Have 2 Behringer Eurolive B 215 Speakers and the 15" woofer have no sound coming out only sound thats coming out is from the horns
These have a crossover inside as well as a fuse. If it is blown the link is gone and only the horns will work.
May 13, 2010 | Behringer Eurolive B212A Speaker
MY PIONEER WOOFERS DOESNT WORK
disconnect it from the amp and use a digital mutimeter and check the resistance, if it's a 4 ohm sub your reading should be close to that number, if the resistance number is below 1 ohm, your sub is probibly blown
Apr 26, 2010 | Pioneer TS-W252R Car Subwoofer
Athena AS-P4100 Sub Woofer - blown main fuse - who repairs these?
Sorry I can't solve your problem. I think the main fuse on mine is blown too. Can you tell me where it is located?
Mar 09, 2010 | Athena AS-P4000 Subwoofer
Hi,i don't seem to have much bass sound,even increasing it on the amp,doesn't make a lot of difference
Without much info - If your system has a separate powered sub woofer, it's not on or not working. If it doesnt, then the speakers (large ones in box) might be blown. Also check for subsonic switch, make sure its off.
Jul 11, 2009 | Audio Players & Recorders
Do you know if my woofer is blown?
well if you hear a rattle sound its probably already blown...and the amp could be drawing too much power if the radio shuts off...make sure all your wiring is correct. also if your car is off and you turn it up it will most likely shut off cause the battery cant handle it. but as for the sub i think its blown. good luck
Nov 16, 2008 | Jl Audio 12W3 Car Subwoofer
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
JBL HLS810 Main / Stereo Speaker Logo
104 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
