JVC KD BT11 CD MP3 CAR RADIO IPOD AUX INPUT BLUETOOTH Car CD Player Logo
Posted on Oct 28, 2009
Unable to play music files from mobile, saying no audio device connected, whereas i can receive the call from the system. Thanks, ..Amit
A
Anonymous
Your stereo have the bluetooth connection to be used only for the headset profile (IE to making and receiving calls). To read the music from the phone you need to connect it using a USB cable and put the phone on "Memory card" or "Mass storage" USB mode.
If that doesn't work is because some phones simply can't be read with devices other than computers because they use windows drivers to enable the data access.
1helpful
How to pair bluetooth with nexus 7
Hi on the bose website it says- No, the Bluetooth mobile phone connectivity is for communications only. so using it on tablets and such would not be compatible. Thanks
Receiver won't play music from an MP3 device
Use your computer speaker as the sound device or use a headphones.
If it sounds good, it could just be your cable that goes to the receiver.
( using a Y cable to connect to one of the regular audio inputs.)
or have one like these:
3.5MM To Stereo Rca Cables: Electronics
30helpful
2answers
I downloaded music on my mp3 player but when i try to play it it says drm license not available
The Digital Rights Management system is blocking your system. This can be a tricky thing to sort out. We need to know what music downloads are blocked - just some or all? What player are you using - iTunes and MS Media player are very active on DRM - Media Monkey is a bit less fussy - you might try it on your computer. Are the files playable on your other equipment. The more info we have the easier it is for us to try and help.
4answers
My nokia 6300 does not receive data via bluetooth it says operation failed but i can send data
nokia 6300 you have to reinstall the bluetooth device in the nokia servies center.and then you can receive dates from other phones.[or] copy the datas to pc and formet the memorycard........
1helpful
Syncing with the Motorola VE240
transfer music to your phone
Before you copy files to your phone, make sure
the files are in a format that the phone recognizes. Your
phone’s music player can play the following types of
audio files: AAC, AAC+, MP3.
To prepare your phone to receive music files:
1 Insert a memory card into your phone (see
page 11).
2 Set your phone to Mass Storage mode by going to - >Settings > USB > Mass Storage.
You should be set. I was having the same problem
3answers
I68 music player problems
I'm having this same exact problem! I purchased a 2GB Micro SD card for my SciPhone i68+, and can transfer music to the card, but it won't recognize it on the phone.
It's frustrating! Any help would be appreciated! Thank yoU!
2answers
Cant plaY MUSIC ON TOM TOM GO 910
Place all mp3's in a folder named mp3
Then it shall find the files...
1helpful
Unable to listen to music
add the music files from your documents to the audio folder not by sync...if have to add the one by one...
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
