Contributor
- Posted on Jan 02, 2008
Re: Dryer will not stay running through entire cycle or...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Load the dryer and start it but it does not stay running. The pannel timer light flashes and then eventually turns off... clothes not dry. This happens all the time; there is no confidence that when you load the dryer, start it, and walk away that when you come back the clothes will be dry... We think it might be problems with the door latches...
is there any heat to the unit? meaning when you open the door is there any heat inside the drum?
Whats the model#?
