Normally pin code would be 0000 (4 zeros) if you haven't change it. DON'T input pin code more than 3 times cos your phone will be locked up if those codes were wrong. But it's just a tricky way to solve your problem.... input wrong pin code to get your phone locked then ask your network provider for pin2 code or puk code to unlock your phone, now you can use a new pin code as your liking.
Hello, If this is the security PIN number, going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input. To unlock the unit, it must be sent back to Garmin.
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input. To unlock the unit, it must be sent back to Garmin.
Hello, Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input. To unlock the unit, it must be sent back to Garmin.
On the pin input screen, select I Forgot. Enter your secret question answer or select I Forgot. Check Inquiry Number – Call Nintendo Customer Service at 1-800-255-3700 and provide the inquiry number shown here, and the date that is set on your Nintendo DSi. You will then be issued a master key. Tap OK. Enter the master key and select OK.
If you input the incorrect PIN code for three times,the sim card will be
locked up,by then, you need to input the PUK code to unlock the sim card, both
codes might have been provided along with the sim card to you,if not,please
contact.. you can get more solutions in our website:
www.1010store.com
