Everytime I turn on my phone its like that.
Nothing's wrong with your phone dear.
If you think Im not sure well I have the same phone and I've had it for a year. So Im sure nothings wrong. As long as its operating fine its ok. Believe me.
Just a little check...
Can you still use the camara?
Can you beam a photo to another phone using bluetooth? If yes, than NOTHING is wrong.
If you have anymore questions I'll be glad to help. Just comment back and I'll try to answer you ASAP.
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
when battery is installed the screen shows 4 even space bars...the top
one red, then green, blue and white with the word "bootload v 0.24" in
the red bar and "SD" in the green bar and its frozen there. I've tried
soft reset, system reset, and hard reset...nothing works.
okay i have a sidekick 3 as well and what you need to do is put the paper clip in the hole again and hold the power button at the same time for approximately 3 seconds. This is a hard reset. Now the bad part is that this will reset all of your data back to factory default. If you need further assistance or this does not work click the ask me button next to my name and we can work on it from there. Thanks.
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks! Thanks
