Sony Playstation 3 (PS3) Console Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ps3 overheats and shuts down - Sony Playstation 3 (PS3) Console
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
27103
Points
327
Do the fans kick on and it gets really loud, if so you can just grab some thermal gel and take the ps3 apart and put thermal gel on the cpu's. if its not getting loud then you may have a bad fan or the motherboard controller for the fan is bad
My playstation3 freezes and when it restart my controlers wont work what can i do?
on the back of your controller there is a reset button have to use a pin to get in and reset it as far as the ps3 freezing its probley the fan going bad and causing the ps3 to overheat, does it just freeze up or shut down.
Shut down while watching movie
Most likely a YLOD problem.
This problem occurs when that PS3 Unit overheats and the GPU or CPU becomes UN-soldiered from the mother board. the only way to repair this is by a re-flow of the soldier under the chips on the board.
This needs to be done by a professional due to the extreme sensitive nature of the internal electronics. There are a few repair services out there. I have been doing these repairs for a few years now and it usually takes me about 2 hours to repair a unit and then I like to test it for 30 hours to make sure it won't overheat anymore.
you can contact me by email if you would like me to fix your unit for you
[email protected]
2helpful
2answers
What can happen if the in the fan in ps3 is not working propserly
is it cold where it is it may not turn on because it not getting hot enough if it is bad it will over heat the hard drive and cpu
Ps3 doesnt display on my tv on regular plug and shuts off after 2 mins
The PS3 combines the features of a game console and a Blu-ray player in one device but like many highly sophisticated devices it can easily overheat. An overheating PS3 displays an LED on the front called the "yellow light of death" and shuts itself off after a few minutes. Repairing a PS3 system so that it doesn't overheat can be done at home, although you will need to open up the case and add heat dissipation paste to the GPU and CPU chips inside of the case. But it costs you more rather you can send the unit to SONY.
My ps3 will go ON but when i try to shut it down it...
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
My Playstation 3 won't stay on. When I turn it on, it shuts itself off immediately and flashes a red light. It is not overheated. What can I do?
Mine did the same thing yesterday. I called PS3 tech support and they said to fill out a service order request, they will send a prepaid box. When I get the pre-paid box send it back and since it is out of warranty, it will cost me $150.00. Will take from the time I fill out the request online to getting my fixed PS3....about 4 weeks. Mine did not overheat, in the middle of a movie...shut down. Nextflix DVD is stuck and they said that they will return the DVD in another mailing. Can not believe that as advanced the PS3 is, there is not an emergancy DVD release like on PC's. Good luck and hope this helps!!
3answers
System freezes
well .... try to install a coolermod in your system...
maybe overheat problem can freeze and you need to shut down your system...
need to power up the rpm of your coller...more ventilation to control overheat..this is coolermod!
Good Luck!
MY PS3 (60 GB) IS COMPLETELY SHUTTING DOWN WITH LITTLE BIG PLANET!
The transistor fiber in the mainframe underneathe the cutter points from the plate outlet is getting overworked despite the fan and ventilation systems. When the operation manifold extends it's forskin to the knee joints of the disc lense, the router governor doesn't recognize it and forgets to shut down and the fan stops running at the proper speed. A patch cannot fix this bug so they have to redo the code before they can put it on store shelves.
Pretty much the delay it has for the game to load overheats your system and causes it to shut down. Id say either contact SONY or the game manufactorer and see if there is anything they can do. I hope this info helps
Shutting down on 60mg system
try holding the power button on the right
side of the console as you turn the back power switch on.Keep on holding the power button and see if there is a double beep.If this doesn't work,and if you want to try this? Open the HDD cover on the left side of the unit(front facing you).after removing the cover,remove the HDD unit and reconnect.It might be a loose HDD connection.This should only take you 2 mins to do and it won't void your warranty
Ps3 game not working
sound like there is a virus in that game disc
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
