If this is a high effeciency model, the venting may not be clear or the drain may be partially plugged. if you hear any sort of water gurgling in the inducer motor, you probably have one of these conditions. if that checks, see if you have 110 volts to the hot surface ignitor. if you read voltage there after the inducer comes up to speed, then you need a new hot surface ignitor. if no voltage, then the pressure switch is still not closing. concentrate on the condensate drain and furnace venting.
Please be more specific in your problem.
