Hi, My 417.43142300 Kenmore drains while trying to fill itself with water. It takes 15 to 30 minutes before it stops draining and finally fills and then spins ok. It takes a lot of time to wash and wastes water. Sometimes, when it gets stuck and I’m around, I turn it off and wait until it drains out. Then I turn it on and it fills within a minute or even less and works ok.
Any help is appreciated.
Try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Testimonial: "What was I thinking about? I checked the manual. You?re absolutely right. Thank you!"
Hi
If you
are noticing that the dishes are not clean, then there are a few things to
check for. Check the soap powder if it's kept in a dry environment. Also try
replacing the powder with something like a gel or liquid. Next thing to check
for is the water pressure and fill valve. Check if the water is filling in and
the spray arms are throwing the water with enough pressure. Try and listen to
the sound if you hear a proper spraying action sound.
If it
seems as a low water pressure then check the fill valve. Now, check if
dishwasher is draining the water or not. While the dishwasher is working check
whether the dishwasher is draining and there is not much left out water after
the cycle is complete. Try cleaning the spray arm with a soft brush. The water
temperature plays a major role in cleaning of dishes. The temp should be
between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
