Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool Gold Ultimate Care II: No heat
I cleaned vents, lint traps, blower motor any thing I could get the vacuum hose at. The lint trap casing was very clogged. I get great air flow but no heat. The dryer is a Whirlpool Gold Ultimate Care II and the model is GGC985HQ!
  • 2 more comments
  • Anonymous Jan 08, 2009
    I have same problem and we are trying to fix it ourselves
  • Donald Menezes May 02, 2013
    YEP USED A 15 AMP AUTO FUSE WORKED LIKE A CHAMP AND NOW MY WIFE CAN DRY HER CLOTHES AND I CAN FINALY TAKE MY NAP ! AND GET THE ORIGINAL PART TOMORROW.
  • Anonymous Mar 13, 2014
    Spins and sounds normal, but no heat.
  • Anonymous Mar 27, 2014
    Hi, I have an Kenmore Eco Care electric dryer model 417.83042201 that doesn't turn off, it has to be manually turned off by moving the timer dial to the "OFF" position or by opening the dryer door. I removed the back vent, dryer vent hose, as well as the lint filter assembly inside and cleaned out all lint debris but it still will not turn off. I welcome any suggestions of how I can remedy this, thank you!
    President:
  • 878 Answers
Didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.Whirlpool Gold Ultimate Care II: No heat - 7152136.jpg
Posted on Jan 01, 2008
I had the same problem, and found you can use 10 amp auto fuse for a temporary fix.
Posted on Apr 02, 2009
  • cilirraent
    cilirraent Apr 16, 2013
    THIS WORKED GREAT GLAD I SAW IT I NEEDED WORK CLOTHES AND HAD NO DRYER
    New Friend:
Heat turns on for short time then off
Posted on Aug 10, 2010
  • Jorge Villalobos Nov 04, 2011
    Did you ever got an answer? I have the same issue with my gas drier.
    Problem Solver:
  • 6 Answers
Thanks to Catriver, I fixed my Whirlpool Gas Dryer, LGR5636EQ2. It wasnt heating up. The heating element wasnt even going on. I checked voltage to the heating element and I wasnt getting any. So, after reading this from Catriver, I took out the Thermal Fuse and checked continuity and there wasnt any. So I replaced it and now the thing works again. !
Posted on Feb 19, 2008
  • danpatron Nov 05, 2008
    Now I have another problem with the dryer months later. The heating is fine, but on the Auto Dry-miser setting (with the *), the knob is not moving to the off position when the clothes are dry. I came back hours later, the clothes were super dry and the unit was still on the * setting. Could it be the timer? If so, how is that changed?
I too checked the Thermal fuse and it wasn;t getting continuity. I will replace the part tomorrow. Thanks for the great website!
Posted on Mar 31, 2008
    New Friend:
Do i have to use GAS? IS IT TRUE I CAN CONVERT TO ELECTRICITY?
Posted on May 28, 2010
4 Suggested Answers
SOURCE:
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
  • 583 Answers
SOURCE: whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Posted on Mar 03, 2009
SOURCE: Whirlpool Duet Dryer - Working but no heat
i need help fixing my 5 year old dryer. whirlpool duet model GEW9200LW1. I have replaced the thermistor. I tested (with an ohm meter) the heating coil, thermal fuse, high limit thermostat, & heating element and they were all fine. I replaced the electronic control assembly and the user interface. THE DRYER STILL WONT HEAT.
Then it occurred to me that the sensor may not allow the dryer to heat if its not sensing wet. Could this be true? Have I been trouble shooting this wrong?
Help me.
Posted on Jun 25, 2010
Where is the trap?
You'll have to be a little more specific please. What kind of trap are you thinking of/referring to? Not aware of any type of "trap " on this model. Are you talking about some sort of lint trap? And what problem/s are you having with the washer (like what's it doing or not doing)?
Aug 10, 2015 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool dryer ler7646eq1 will not heat
First the most obvious and you've most likely covered yourself look at the lint trap/if clogged clean thoroughly with vacuum cleaner pull out lint trap and **** up as far as deep as you can get some of the lint that you don't see and believe me there's a ton depending on your exhaust/vent type . Next go outside check the vent attached to the outside of home for clogs/lint buildup lastly here's a trick I've personally used SEVERAL TIMES on my old ge dryer if you have a LEAF BLOWER pull dryer out of the way and next go outside remove exhast vent usually 4 phippls screws going out next remove vent/trap outside go back inside and use the leaf blower to blow out all of the lint caught in the vent tube your be surprised how much was in there. HOPE this quick fix addresses your dryer issue if not its most likely the dryers thermostat they're fairly cheap online. Just trying to save you a buck friend. Have a good day Ryan in Minnesota
Oct 17, 2012 | Whirlpool Dryers
Heats but doesn't dry
If your clothes are coming out hot but still wet you have a vent problem Either the lint trap at the dryer is clogged or the vent coming out of the dryer to the outside has a build up of lint. If you don't clean the blockage it will burn out the heating elements and cause you more problems. A shop vacuum will take care of both problems in cleaning out lint trap and dryer vent
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
Dec 13, 2009 | LG DLG2524 Gas Dryer
HOW DO I CLEAN OUT THE LINT TRAP ? THE MACHINE IS @ 6 YEARS OLD AND NOW I AM HAVING SEWER PROBLEMNS CAUSED BY LINT FROM THE WASHER.
I did not fix the problem, I called a plumber and fixed the sewer. So I will still have a problem with the lint trap on the washer. It is supposed to be self cleaning, but I have my doubts.
Mar 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How To Open Bottom of Dryer
Take the back cover off and there is a compartment that hook to the hose, with the right tools you can pull the compartment out and clean it to include other parts showing. hope I helped allittle.
Mar 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer not drying clothes very well
Is the dryer getting hot? Is the airflow coming out of the exhaust strong? If the airflow is good, but not hot, the problem is most likely a thermal limit sensor.(These sensors determine the air temperature, and cycle the heat source) If the airflow is not forceful, but the vent hose, exhaust vent, and lint trap are clear, then the blower/fan may be encrusted with lint, or broken. The sensors and blower can be difficult to get to, for cleaning or replacement, but possible. It depends on your skill level. Remember to always disconnect the power when attempting a repair on any electrical device!
Dec 02, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool GGQ8831L Gas Dryer Logo
12,695 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
