Dayton G73 Utility Heater Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i connect load wires to 240 volt baseboard heater
Trouble shooting baseboard heater Not sure where to connect the two 120 volt load wires to my new dayton brand baseboard heater. I have electrical experience but not sure about this one. P/N 3UG87D DAYTON 240 VOLT. thanks SHAWNNA
Ken Thomas
Level 2:
  • Expert 118 Answers
  • Posted on Oct 27, 2009
Ken Thomas
Expert
Level 2:
Answers
118
Questions
Helped
48033
Points
228
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
2 Related Answers
Anonymous
  • 33 Answers
  • Posted on Oct 28, 2009
SOURCE: Where do i connect load wires to 240 volt baseboard heater
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Anonymous
  • 89 Answers
  • Posted on Nov 01, 2009
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
1helpful
2answers
I have a FahrenheatPro. and it doesn't seems to not throw out hea
the baseboard heaters out put goes down a lot more than you would think when used on 120 volts ... thats because not only is the voltage half of what it should be, the current is also half .. so the total power (the product of voltage and current) is one fourth of what it would be if operated on 240 volts .. you are operating at only 186 watts instead of the 750 watts you should have .. so you would have to have 4 times as many heaters for the same heat output .. you likely have the 240 volts available (most houses do) .. there are two phases .. each 120 volts .. when both phases are used together then you get the 240 volts total .. another option is you can use heaters designed for 120 volts .. the current would increase to a little more than 6 amps per heater .. some heaters have a jumper you can move for 120 volt service or 240 volt service... you can use those with either voltage ..
Heater is not heating up.
First, is this a 120 VAC or 240 VAC heater? 120 VAC heater will usually have one Black & one White wire and 240 VAC heater will usually have two Black wires or one Black & one Red wire. If it is a 120 VAC heater then you need to supply the white wire at the heater with a neutral (white) wire from the breaker panel. If it is a 240 VAC heater then you need to verify that you have 240 VAC at the heater from Black lead to Red lead. If you are not sure about how to do this please have an experienced electrician look at it so you don't get electrocuted and/or burn up your new heater. Hope this helps!
Marley electric 3ft. basebord ,wiring w/thermostat
If your baseboard heater is rated at 220 VAC and you have wired it to a 120 VAC source then the heater will only produce about 1/4 of its rated output wattage. So, if you have a 2000 W / 240 V heater it will only produce about 500 W at 120 V. You may want to have an experienced technician wire it for you if you are not sure what you are doing. Please be careful and smart when dealing with electricity!!
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Replacing old with new
Are the heaters rated at the same voltage, if so just connect the white to one heater wires and the black to the other heater wire..Does the white wire have a tape around it. If it does that indicates that it is a 120 volt cuircuit and not a neutral, which means you have a 240 volt supply. Make sure your heater is 240 vac.
2answers
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
6helpful
3answers
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
3helpful
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Top Dayton Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
