Win Tyler,
Information on resolving your locked screen on your LCD is listed below.
In the TV Menu Settings menu you can
select TV Button lock to lock the TV
Menu and the side panel buttons. When
this option is enabled, only the power
button functions. To unlock the TV Menu
and side panel buttons:
1. Press the Menu button on the TV. A message appears stating that the TV is locked
2. While the message is on the TV, press the channel up and volume increase button
simultaneously.
If you are using the DVI connector, you may need to verify the following settings:
Source - The default setting is Auto. The T V automatically detects if a computer (PC) or video
device is being used. If the image does not display correctly, you can select the source, PC or
Video, depending on the device you are using.
Color - The default color space is RGB. If the colors are not displaying correctly, you can change
the setting to YUV.
You can download and view the online users manual from the link below.
Manuals & documentation for your LCD TV W2306C
Product Support
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Already check with Dell and on Ebay. Nothing available.
