Motorola Mobility H270 Bluetooth Headset Logo
Posted on Oct 27, 2009
I have a H270 Bluetooth headset. I charged it
I have a H270 Bluetooth headset. I charged it yesterday and now the blue light is always on. The power button doesn't seem to work (doesn't turn on or off). Can I reset it or do you have other thoughts?
  • Anonymous Mar 28, 2014
    Blue light is stuck on and wont turn off
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
4759
Points
55
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
  • ptum Jan 14, 2011
    Excellent help....This has happened to me several times because I'd plug in the charger to the headset without actually switching it off, so once fully charge, it appeared to "hang" so each time it happened, I was waiting for it to completely discharge before re-charging it again, rememering to switch it off firstly....your solution has saved me a couple of days waiting for the device to discharge....Many thanks, most grateful !
  • Anonymous Dec 23, 2011
    Mines wont take any charge at all. If the power switch is on it doesnt work, if it is off it doesnt work i need help
2answers
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? [email protected]
2helpful
My motorola h270 bluetooth device will not connect to my sprint lg rumor 2 can you help me solve this problem. thanks
Charge your bluetooth device fully.
when ready, turn on your phone's bluetooth software (settings/bluetooth/on)
press and HOLD the power button on your device until it blinks 3 times (or continuously) wait for your phone to see it.
Usually the pairing code is 0000
the phone should let you know when it is complete.
Good luck.
I'm charging the headset and the led is blinking red, but when i disconnect the usb, i still can't turn it on
When the headset's battery is fully charged (about 3 hours), the indicator light is steadily lit in blue
13helpful
I can't get the blue light to shut off, even when i power it off. it also will not pair with my bbery device
I had the same problem. I plugged a USB cable from m laptrop into the headset and turned the headset switch OFF. It worked normally after that, I was able to pair it. I don't recall if the power switch was "on" when I un plugged it from my car charger but maybe it doesn't like that.
13helpful
Power switch light,won't go off the call light is solid blue and there is no reaction when I turn the power on or off
17helpful
2answers
Motorola bluetooth H270 solid blue light after pairing
29helpful
2answers
My motorola bluetooth h270 appears to be frozen. It won't power off, and won't connect to my phone. Whether switch is in off or on position, blue light stays on.
Put it on charging once again. While it is charging, switch it off. It should go off now. Now, remove from charging and switch it back on. Hope it works for you
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
