3Com NBX 2102 IP Phone Logo
Posted on Oct 21, 2017
A user's phone calls keep dropping out during calls incoming or outgoing and the time of each call varies. We have two 3MB T1s installed in two different sites connected over MPLS. Were not having bandwidth issues at all and this is isolated to a single user with the 3Com 2102 model phone. Anyone know of a solution to this or a cause at least?
Nathan Holmes
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 25 Answers
  • Posted on Sep 15, 2018
Nathan Holmes
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
25
Questions
0
Helped
4486
Points
38
I would recommend starting with what is simple.
Have you tried replacing the Ethernet patch cord that the phone is connected to?
How about the curly cord between the phone and handset?
Does the phone do the same thing if you connect it to a different port?
Does a different phone do the same then when connected where this phone is connected?
1 Related Answer
Anonymous
  • Posted on Nov 06, 2009
SOURCE: 3com nbx 2102 issue - have had 2 phones i 1 week
3Com stopped making these phones 4 or 5 years ago. I would suggest contacting the merchant from whom yu purchased them for support.
I have samsung galaxy duos gt s 7582 having problem of no sound during incoming and outgoing call sometime
now i m in roming and my outgoing call is off but incoming is on..and software is also update but no soulation ...
Instructions for 3 way calling
During a call (either incoming or outgoing), the '3-way Call' option will show on-screen. Either select it and press 'OK' or press the digit corresponding to that function. By the way, if your phone's user guide happens to be missing, feel free to download it from this location. Please, let me know if I can help you any further.
Regards, Carlos
My samsung s5233 tuch screen phone show 'service not allowed' during outgoing calls but it can receive incoming calls.
In the settings menu, you are able to disable the ability to make outgoing calls. You will need the security code for the phone in order to change this.
JINCEN 777S dual sim phone keeps dropping calls
you may have to get another phone or your sim is proabally damaged and or your signal is not good
How to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
2answers
Call barring
Use the network services menu for this...
Use this menu to access network services. Please
contact your service provider to check their availability and subscribe to them, if you wish.
This network service allows you to restrict your calls.
1. Select a call barring option:
All outgoing: prohibit outgoing calls.
International: prohibit international calls.
International except home: only allow calls
to numbers within the current country when
you are abroad, and to your home country.
All incoming: prohibit incoming calls.
Incoming while abroad: prohibit incoming
calls when you use your phone outside of your
home country.
Cancel all: cancel all call barring settings,
allowing to be sent and received normally.
Change barring password: change the call
barring password obtained from your service
provider.
2. Select the type of calls to be barred.
home country.
provider.
if you have any queries about your mobile..you can have a look at this user manual which can be downloaded from
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D600-_E
hope this helps :)
2answers
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
2answers
Incoming or outgoing calls no sounds
Turn up the volumes on Ear piece -during- a call (on the side of the phone <===>) and on the speaker at any time. The joy stick does it I think.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
