My hotpoint aquarius tdc32 condenser tumble dryer is not getting hot. An engineer fixed a similar problem some time ago, and said that he reset a overheat cut off switch (but didn't show me how).
I've taken a panel off of the back where I can see what appear to be heating elements. Above this are 2 (1cm) round connectors with 2 wires going into each. These are all that are visible. The rear of 1 switch seems accessible and seems to 'click'. Would this be the switch? Nothing appears to change.
Any help appreciated
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
SOURCE: The Hotpoint Aquarius TDC32 dryer appears to keep
this video will show you how to fix your dryers thermostats
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
SOURCE: tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Testimonial: "Straight-Forward answers, quick - ace!"
