After you aligned the timing marks and tightened up the tensioner pulley, did you re-check your timing marks? Usually when you tighten the tensioner it will pull the cam and crank out of alignment. Line up the crankshaft first and then check to see where your cam gear is. If it is not lined up, loosen the tensioner and move the cam gear ahead to line it back up. If it doesn't line up perfectly then go AHEAD until the marks line up and put the belt back on. If the gear is on the mark and the belt teeth don't line up, move the gear ahead until you can get the belt on,but no more than a full tooth on the belt. Tighten your tensioner and check again. At most the cam sprocket should only be off about 1/2 tooth from the marks and it should be ahead not behind. Re-align your distributor to #1 and it should start. Hope this helps.
The solution is simple. Please tap the screen exactly in the center of the '+' sign that appears on the screen. The + sign or the target keeps moving till the screen is not alligned. I faced the same problem and searched and found your query on many forums but no luck. So I actually resorted to aiming the target with one eye closed...and the damn thing worked in one shot.....Now my default settings have been installed. Lets see what is in store on the other side of the default installation.
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
You should align your screen by tapping each time (Just tap a bit carefully and with a little bit more pressure) that cross shows up during the setup process. It should take 4-5 steps and at the end you can follow the other setup instructions. Hope this helps.
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
