the information I provided was exactly what you requested and I think that I should have gotten a somewhat better rating on this request. Thank you for the rating provided.the information I provided was exactly what you requested and I think that I should have gotten a somewhat better rating on this request. Thank you for the rating provided.
You can't post conmments that contain an email address.
NR83 is the stick nailer. There was two versions. The NR83A was for full round head nails and the NR83AA was for the clipped head nails. The coil nailer was the NV83A was the coil nailer. Here are links for the parts diagrams of all 3 so you can see if one of these is what you have.
The condition of the driver oring is an indication of wear of all the other orings in the gun. Remove the nails and lightly tap the nose against piece of wood. If the driver drops to bottom of cylinder the oring is worn out and time for oring kit. Hitachi nailers are sensitive and will double fire if placing the foot against work then depressing trigger. Adjust the depth thumb screw several turns either direction then depress trigger and quickly bump gun against work. Good luck with your repair.
I have a older Hitachi 3 1/2 full roundhead nailer and on my there is a button on the front below the head at the end of the nails that you push sideways and hold and slide the nail gun tip up or down. There should be grooves across the front of the tip.
My Guess is that it needs a new "O " ring or some other form of seal some where round the trigger actuating spindle. Should be quite easy to fit if you can get one the right size
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
The NR83a has an adjustment just below the triggering plunger. It is a 6mm hex head bolt with a locking nut. Loosen the nut and adjust screw out several turns and re-test. Make adjustment as necessary. I have seen many of these gun without the locking nut which allows the bolt the adjust itself all the way down. AS parts wear this screw needs to be adjusted. The pushing lever and the plunger are wearing smaller/shorter, that is unless the locking nut was missing. Remove gun from air supply for safety when making adjustments. Good Luck an email if you have other qustion about this gun.
