Check the fuel for expiration date (on the bottom) also check for proper nail guage and for the tool being dirty and requiring cleaning and servicing. Also look for a bent safety. When it won't fire again is the driver retracted? If not it is probably dirty. Does it try to fire, you can check the spark unit before spending alot of money on it. Let me know and I will try and help
Also have a look at the micro switch on the rear of the gun by the fan, when the safety is pressed it activates the micro switch. If this is bent alittle when the gun warms up it will not activate properly.
Bend it up alittle and make sure the screw holding it in place is not too tight as this affects the activation of the switch.
Hope this helps
Check the o-rings on the firing pin...
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
