There is a fuse inside the microwave oven but i don't recommend opening the oven and changing it. There are high voltages inside even when the oven is disconnected from the mains.
But if you are careful enough, you can change it. If it has a electronic control (With a digital display) maybe there is another fuse on the controller board, near the front panel.
Before even opening the oven, make sure it doesn't work on another power outlet.
And make sure you change it with the same type and rating of fuse!
