I got an AMD X2 3800+ 2.0 Ghz overclocked to 2.5 Ghz with 1GB DDR dual channel at 400 Mhz and a 8600 GTS 256Mb graphics card. The problem is that the game doesnt run smoothly at all! Both cores run at 100% and it seems the game is too heavy though my hardware is more than efficient for the minimum requirements to play the game. Whats the problem and i cant run the game smoothly? The games freezes (and the sound too) for a few seconds, then starts again for a few frames, freezes again, and so on. I have run Crysis, all the Call of Duty series, Brothers in Arms Hell's Highway, and many other demanding games of the same kind and i never had ANY problem running all of them except this one! Not to mention that i got all the updated Nvidia drivers for my graphics card, the Physx, etc.
Any suggestions to help me?
SOURCE: pc shutdown whilst during gameplay online
its either a driver or a game update needed do you have vista or xp if you have vista that's the problem
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
