My jeep jogging stroller has a flat. Do I need to buy a whole new tube or can fix a flat work? I hear this is a common issue.
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Fix a flat will work if there is not a big hole. Make sure the tire is seated on the rim before you use fix a flat.
