The dishes go in rinsed and food-free, they come out with pieces of food or something over everything! Is there a filter or something I need to clean?
There is no filter except the screen in the water inlet valve to keep big pieces of grit in the water from defecting the inlet valve..
i dont know exactly why but it sounds like your unit was not installed with a recommended air gap in the drain or something similar and somehow dirty sink/drain/sewer water is making its way back into the unit and onto your dishes.
often times there is a little rubber check valve/flapper in the drain line either installed in the pump or the drain hose just after the pump to keep foreign material from entering the unit..
other than that it would just be mineral and calcium deposits if you are on well water or chunky city water..
hope this helps,
best of luck,
ttfn
