Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Posted on Oct 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washingmachine stopped working and gave off burning smell. How can I determine if its the motor thats burned out or something else?
Bill Jones
Level 2:
Habit-Forming:
New Friend:
  • Expert 66 Answers
  • Posted on Oct 27, 2009
Bill Jones
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
66
Questions
7
Helped
15913
Points
155
Had one similar to this about three years ago. That burning smell would be the belt that runs the washer. Relatively easy to repair. You'll need make and model number to get the right replacement belt. Once you have it, get up under it, remove the old belt and put the new one on the same way. The belt will go around the pulley on the bottom of the washer drum, the motor and the tensioner. This should solve your problem. If you need more help, please let me know.
Anonymous
Level 3:
  • Master 464 Answers
Anonymous
Master
Level 3:
Answers
464
Questions
0
Helped
115957
Points
1430
I would be checking the belt first. #28 in the diagram. part # for ordering is 134161100. hope tMy washingmachine stopped working and gave off - 250his helps.
1helpful
HI. My Yamaha D80 while playing gave a burned smell and than sound quit. Rest works. I opened rearcover and notice 3rd fuse in the back was blown. Changed it. Blew again. So I stopped fidling around.
If the fuse blows and a smell of burning is present then its obvious there i a fault somewhere ahead of the fuse, the fuse is a protection device.
1helpful
2answers
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
1helpful
When running it smells like something is burning
Hi
If it smells like burning rubber, then your belt is probably slipping due to having lost tension and needs to be replaced. If it's another smell, it could be the motor burning out, but that is often accompanied by smoke. There could also be something caught around the revolving brushes in the cleaning head. Lie the vacuum on it's side and make sure you can spin the brushbar freely by hand. Also check for any debris entangled in or obstructing the brushes. This would also cause the belt to slip resulting in a smell of burning rubber. It could also damage the motor so I suggest not using the vacuum until the source of the fault has been determined.
Instructions on replacing the belt can be found in your user manual. If you don't have one or need further instruction on how to do this, please post back for further assistance.
Regards,
BElectric.
The blender stopped working
the motor is burnt. replace with the same motor or have it rewound.
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
1helpful
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
2helpful
Burning smell
That burning smell was possibly the motor windings burning out. If the windings have burned the blender will need to be replaced. Hope this has helped you today,.......... Sea Breeze
Please let me know if this answered you question.
Washer smells like something is burning and it won't work at all
i would check the motor, and also the coupler that mates the motor to the tranny
2helpful
4answers
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
