Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin wirless router lose signal after approx. 30
Belkin wirless router laptop computer lose signal after approx. 30 feet from the router.
  • 70 Answers
Try to change the channel of the router, make sure there are no cordless phones or other w/l interferences around it. still if u have same issue, update the firmware by downloading latest file from belkin's website.
Posted on Jan 14, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 116 Answers
Sounds about right, that's why they are cheap. Try adding a belkin wireless range extender.
Posted on Nov 13, 2009
  • 2,277 Answers
Check the wireless channel on the router.
Is it properly set ?
you can try changing the wireless channel on the router.
Or if that doesn't work then you can try to upgrade the firmware of the router.
for this you will need to open the set up interface of the router.
Click Here to know more about routers
Posted on Oct 27, 2009
SOURCE:
Belkin router is getting disconnect in every 2minutes on my tablet pc
How many devices are connected to the wireless? Are you moving about when you lose the signal? Is the wireless Secured? If you have other computers/laptops connected do they lose signal? Many thing will cause loss of a signal, much like a cell phone.
Jan 30, 2013 | Belkin Computers & Internet
I have a Linksys by CISCO Wirless-G WRT54G2 Router connected to a High Speed Ethernet Modem and to my Desktop Computer. It gets fairly good signal sent to my laptop across my house. I also have a Belkin...
If your computer has 3 bars of signal, it's ok, don't mess with it.
If you want better reception, you can connect the Belkin wireless router near your notebook with a cable to the Linksys router.
Nov 04, 2009 | Computers & Internet
Keep losing my wireless signal. always have to disconnect and reconnect. Happens on my computer and now also on my ipod. Only fix i found is reseting the router. I have a Belkin N1
Enable 802.11g only disabled DHCP use CH6 and WPA also set the Bandwidth to 20/40 MHz instead of just 20 MHz. Also upgrade firmware if you haven't done so.
Oct 22, 2009 | Belkin Computers & Internet
D Link Wireless N router keeps having to be re-set
I've seen this on a router that was broadcasting very little signal. (in my case the next day it died. When the laptop is running move away from your router and try to determine where it loses signal strength. A router is good from the factory for about 200 feet with no obstructions. In most homes I give them 30 to 40 feet. Be aware that windows and glass doors nowdays use a metal mylar film between the glass to reduce infrared rays. If you lose the signal very soon then I'd say the router is dying.
Good Luck
Mar 22, 2009 | D-Link Computers & Internet
Connecting to a lapto
Hi rgf47331,
When you move upstairs there is a solid wall in between that interfears with the signals.The only thing you can try is calling up belikin and asking them to check your settings on the router and see if changing the mode or channel helps. i wont recommend you do that on your own as you may end losing the connection altogether.
I hope this helped
Keshey
Feb 16, 2009 | Belkin (F5D7230-4) Router (587009)
Modem and internet signals were lost on the Belkin router
Find the reset button on the router and start over!
Dec 21, 2008 | Belkin Computers & Internet
Keep losing internet signal
Have you tried updating the firmware of your router? Updating the firmware of the router will fix that issue. Make sure after updating the router's firmware, hard reset the router. To hard reset it, Press the reset button on the back of the router for about 20 seconds, then unplug the power for 30 seconds then plug it back. Reconfigure the wireless settings of the router. Make sure to change the wireless channel of the router to channel 11 or 1 and not 6 to avoid interference.
Sep 16, 2008 | Belkin (F5D9230-4) Wireless Router...
Wireless signal
right click on your network icon in the taskbar and go to view connections and clear all connections and allow it to find the connections again, this time it should find yours first
Aug 21, 2008 | Belkin (F5D7231-4) Wireless Router
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at www.belkin.com/support
Jul 19, 2008 | Belkin Computers & Internet
Belkin wireless router keeps losing the internet
My laptop has been getting knocked off alot with this router as well, i started looking around online for advice and this is what i found if you go to your router's set up utility.......i get there by typing 192.168.2.1 in the address bar. look for firmware update.
Jan 14, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
138 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
