OVEN COMES ON FOR ABOUT 45 SEC. THEN ERROR F1-E POPS UP ON DISPLAY. AND IT GOES OFF
Your erc(clock) is bad.
Testimonial: "VERY HEPFUL. THANKS"
JENN
AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F1
Defective
touch pad or membrane
Replace touch
pad or membrane (this problem is usually the touch pad)
F1
Watchdog on
board
Replace touch
pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay
board (if present) or oven temperature sensor
F3 or F4
Open or shorted
Replace oven
temperature sensor
F5
Hardware and
watchdog circuits disagree
Replace clock
F6
Missing AC
signal
Check for
proper voltage
F7
Function key
shorted or stuck button
Replace touch
pad or clock assembly (also called the ERC) or attempt to
un-stick button
F8
Analog/Digital
supervisory
Replace clock
F9
Door latch
supervisory
Check door
lock circuit or replace clock assembly (also called the
ERC)
F0
Function key
stuck
Replace touch
I have a kenmore and these codes pop in and shut off oven f2,f3,f5
If you have a difficult time finding a new control board or want to save some money, these can be repaired quickly and reliably.
