Question about GE Spacemaker 26976 Cordless Phone
The hand set has no dial tone. Also the display turns off and the phone beeps once shortly after the "Talk" button is pushed. I replaced the battery but still get the same results. Do I need a new handset and if so is a replacement availabe? Thanks, Larry
    New Friend:
Unplugged wall unit from the 110 volt outlet and the phone line from the unit for about 10 or more minutes. The phone worked after the phone line was reconnected and the wall unit plugged back in.
Dont know which solved the problem but I suspect it might have been unpluging from the 110 which could have reset the wall unit.
Posted on Oct 27, 2009
SOURCE:
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
Hi.
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 | Cell Phones
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
I have uniden exa 915 . Problem: When you pick up the cordless hand set and push the talk button you get a beep,beep,beep and but no dial tone.I put a new battery in two mo. ago and just to make sure I put...
Its lost its "link" to the base unit, you need to re link them this is either dont thru the menu system on the handset or pushing a button underneath the base unit and THEN re linking it via the menu.
Oct 23, 2009 | Uniden Lands Phones
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
No dial tone when the talk button is pushed
the circut inside is acting up and will need repair, this can happen whenthe batterys are low in the phones and the base does not detect them , also the detect circut coud be bad , and or the automatic pick up circut for the answering machine
Oct 15, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
No dial tone
the power supply of your phone is shorted,you need to coldsolder the components of your pcd.
Apr 05, 2008 | Uniden Cordless Phone
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Recharging phone constant beep
When misplaced in the charger the xg2200 beeps, are you sure the phone is placed correctly? please let me know. Good Luck
Mar 01, 2006 | Xact Communication XG2200 Cordless Phone
GE Spacemaker 26976 Cordless Phone Logo
158 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
