1992 Saturn SL2 Logo
Posted on Oct 26, 2009
Fuel gage is not working along with odometer checked for fuses did not find took apart dash found nothing there what should i check next. Tempature gage and oil pressure gage still work fuel gage is right in the middle of those gages
Gary Floyd
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 12, 2009
 Gary Floyd
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
1979
Points
8
When you pulled the top of the dash off did you check the cable connection to the insturment cluster. i had a similar problem where my gauges died individually including the spedo and tach. slapping the dash usually would cause the gauges to start working again, but that quit also and i had to tear the cluster out and check the conneciton. that fixed the problem.
3answers
Dashboard instrument cluster faulty - fuel gage, odometer, tacho and trip counter not working on my nisan n13. Fuel gage shows pessimistic eatimat of fuel in tank. Odometer stopped one year ago when the...
N13's are terrible for this problem, the odometer stops because of a faulty little nylon cog that has to be replaced, the tacho and gauges in n13 dashed die as well but as far as I know that's because of faulty electronics, if it was just the odometer problem you couldv'e bought the cog off ebay (and with a little mechanical knowledge) you could've taken the dash apart and re installed it yourself but because the other electronics are dying I advise you take it to a dash repairer or you can try getting out a soldeing iron and try to replace all the faulty connections yourself.
2answers
The odometrer, speedometer, gas gage are not working
Has anyone had the dash out? If you take the dash out there is a cable connected to the odometer and the speedometer it is just one cable. And some wires going to the gas gage. Check and make sure the cable is connected all the way. The gas gage may also be disconnected somewhere but there could be different problems that cause the gas gage to be disabled. !Never touch two wires at the same time!
4helpful
3answers
Gages speedo tac all quit. fuses are good 98 jeep wrangler. did it before but came back on. changed gage cluster still will not work
Have you checked it with a scan tool to be sure it is actually getting the information? The instrument cluster do go out, meaning the ribbon on the back.I would check the connection, then turn to a way to determine if it is recieving a signal from ECM.
Check engine light came on, along with low fuel indicator.
I took the vehicle to the Jeep dealership, and the problem went away before they could check it out. They are going to check wiriing next, because the check engine light went out on its own, and the fuel gage began working corectly on its own. Not sure what caused it, but hope to have an answer from the dealer.
94 ford probe,speedometor,oil gage,odometer not working
You need to pull the dash and check the guages look for any burning or melting. You may just need to replace the pannel in your dash, pretty easy work. If not start checking the wires and cables that come out of your faulty guages.
tepfy
My gages stopped working inside my car no speedometer, oil or tempature gages what could be the problem?
Not sure, but on most newer cars they have fuse for the gauges under the dash you may want to check to see if it's blown
2answers
The dash gages are not working, fuel gage, speedo, temp gage
Is this the only problem? How did you check the fuses?
2helpful
2answers
1998 Contour Speedometer, gas gage, odometer not working
check the relay for the dash gauges.
Robert
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
