Anonymous Posted on Oct 26, 2009
Hi, Ive tried to set up my samsung blue ray
Hi, Ive tried to set up my samsung blue ray home cinema HT-BD1220 2.1 to my samsung led tv. I can get the speakers and woofer to work when playing a cd etc but can only get the tv to use the tv speakers when watching sky.How do i set up so the speakers and woofer are on all the time?
Anonymous
Level 3:
  • Master 350 Answers
  • Posted on Oct 26, 2009
Anonymous
Master
Level 3:
Answers
350
Questions
0
Helped
137515
Points
1214
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Testimonial: "Hi thanks for the reply, ive now got it working, i needed to attach an Optical lead from the Home cinema to the Sky box which they didnt supply."
2answers
Samsung ht-bd1220 ipod problems.
Having the same problem- did you manage to sort this out?
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Home Cinema Samsung HT Z310R- Speakers not working with TV
You need just one cable that goes from your TV to your HT system.
On your TV you should see an RCA jack for "AUDIO OUT" and you need to plug that into your AUXILLARY "AUDIO IN" on your HT system
When you are watching TV and you want the sound to come through the HT system, just set the HT system to "AUX" mode. Most Samsung systems will have 3 'AUX' modes, set the remote on 'AUX 1' then wait a few seconds, if no sound comes through then set it on "AUX 2" wait a few seconds and if it doean't work try AUX 3.
Hope that helps.
Gary
Advice on the best way to connect
If your system has hdmi in puts put the blu ray player into it then from hdmi out on system to hdmi in on your tv.Now take a phono lead from tv out put to a input on your system,could be marked "aux,tv,sat".For tv sound set the system to prologic2,blu rays should decode themselves,if not check settings for audio out on player.
hope this helps.
cable guy.
13helpful
2answers
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
