SOURCE: my ps3 is broken
okay if the problem persists every time you turn your system on, try holding the on button on the front of the console down until you hear a second beep. that will reset the system. if the system turns on without the screen, back up your data onto an external hard drive, and reinstall the ps3 through the settings menu. the reason that you are getting this error is either because of faulty hardware or software. so we are going to try the software approach first, if this doesn't work, please message me back saying if it did or not.
SOURCE: my ps3 has a red error screen saying contact tech. support
check security settings? may need to reset.
SOURCE: When i turn on my ps3 a red screen comes up
Usually it's a motherboard issue, but you can try booting the PS3 WITHOUT the hard drive installed and see what happens.
Let me know.
SOURCE: PS3 is "on", red screen has occurred with a error warning
this is probably an warning about problems with your hardware (such as gpu or ram modules) .
The only thing you can do is taking the system to an assistance centre for hardware checking, they will test all the components of the system .
if your system is covered by warranty, don't waste time and call sony as soon as you can !!
unfortunately, there isn't any firmware solution to fix it, because all system functionality is prejudiced.
the only thing you can do (i belive it wont work), is reseting av settings by holding the on;off button when starting up the system .
Hi Ernesto,
If you are getting this error it is called the no display error.
Cause:
The reason that it happens is because the GPU which deals with all of your
graphics has overheated. You just need to stop the heat build up in order to
make it work again.
Solution:
The first way you can fix the No
Display Error is by sending it in but bear in mind for this problem
there is a $150 charge for the repair which is pretty steep!
Alternative Solution That Is Faster:
If you want to get the problem fixed EVEN FASTER than the option for you is a
good PS3 Repair Guide.
NOTE: MAKE SURE You Check Out A Complete Review Of The Top PS3 Repair Guides First!
