Hello Rupesh,
Following is the description for Error 232
A communication failure (comm error) has occurred between the two machines.
OR
The user at the remote machine may have pressed
CANCEL.
OR
The power at the remote machine has been interrupted, or deliberately turned off, causing the fax session to be interrupted
Re-attempt the fax reception at a different time when telephone line conditions have improved.
If the error persists, and error correction is in use for the fax session, disable ECM
Disable V.34 on local machine
V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON.
Follow the steps below to disable V.34 setting.
Press Menu/Enter.
Press the < or > buttons to select Fax Setup, then press Menu/Enter.
Press the < or > buttons to select All Faxes, then press Menu/Enter.
Press the < or > buttons to select V.34, then press Menu/Enter.
Press the < or > buttons to select OFF, then press Menu/Enter to save the selection.
top
Disable or Enable the ECM
Press Menu/Enter.
Press the < or > buttons to select ECM, then press Menu/Enter.
Press the < or > buttons to select OFF or ON, then press Menu/Enter to save the selection.
NOTE: The default setting for ECM is ON.
