There is a seam around the edge of the Thermostat , a small screwdriver or butter knife should do the trick , if not then its mounted to a plate on the wall that has 4 corners basically...Gently squeeze the bottom and pull the bottom out , they are pretty sturdy and you shouldn't have a problem,...the wall plate may flex a little while doing this
