Look at the brush from the side.. The surface that rides on the armature is curved> One leg is longer than the other leg. The long leg is the trailing and the short is the leading edge. Looking at the cooper end of the motor you can tell which way the motor rotates by the traces the brushes make. The leading edge will be on the clean side and the trailing edge is the side that is smeared black.on tthe copper. The long leg of the curve on each brush goes on the smearch side of those copper bars the brush rides on. Both brushes. Looking in the hole of the brush holders you will see what I mean. When you put the brushes in, you must make sure they are up against the copper and the springs are holding them down evenly.. You can lift the brush carefully and let it go to make sure it is working freely. Now, see if you can put an attachment on and turn it by hand. I'm not sure you will be able to so don't bend anything or hurt yourself.. Put the brush caps back on, remove the attachment and plug the mixer in.. Attachments off, fingers clear, turn it on. Does it run? If not, tap the mixer on its side with your hand.. Make sure the switch is on high. Tap it several times if need be. This is to straighten up the brushes to where the springs want them. When the motor starts turning, slight taps help. Keep it going until it picks up speed and let run for five minutes to seat the brushes. Let me know if it still won't run. I'll be watching for a comment from you.
Testimonial: "thanks so much, next time if it works, i won't try to fix it!!!!!!!!! thanks very much"
It's a pleasure to help anyone that fears no machine and is willing to explore or take on a chhallenge. I hope the mixer is working, If not let me know.AAny time you need help, [email protected] will get do his best to help.
Notice how the magnets are shaped. Use the flash light to look inside the hole. Make sure the the little square inside the hole fits where the dent on the magnet is. or it won't transfer the power to the amature. The brushes only fit in one way so line it up correctly.
