Heating & Cooling Logo
Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I need to add oil to this heater? it just shut
Do I need to add oil to this heater? it just shut itself off and won't work anymore. Is the heater broken? it's model OFH3600
Anonymous
Level 2:
  • Expert 89 Answers
  • Posted on Nov 01, 2009
Anonymous
Expert
Level 2:
Answers
89
Questions
Helped
35564
Points
143
It' probably just the switch or thermostat
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
My lawn mower won't start. It needs oil. It
Yes... most have oil sensors which shut them down bwfroe damage is done...and if not what can it hurt now???
Put oil in it and try it..
heatman101
WHERE DO YOU ADD OIL TO THE HEATER AND WHAT KING D OF OIL DOES IT USE?
As far as I know you never add oil ... it's a sealed unit. The only way it would ever need oil is if it leaked. Then it would probably cost more to fix than replace
Do you ever have to add oil if so where is the fill cap
Those units are sealed, this traps the oil inside and provides a maintenance free heating system.
There is no need to and therefore no provision made to add oil to the heater.
heatman101
2000 Monte Carlo blinkers work some time have to tap /hit dash board by hazard switch to make them work. Control switch on heater blower not working light out. I have to put the fuse in on passenger side...
For the blinkers you need to replace the hazard switch.This will take care of your problem.For the blower,if this is what you mean by heater won`t shut off.You need to replace the blower motor resistor.This will fix your blower not shutting off.The light for the knob you will have to remove the control panel and replace the bulb if it is replacable.Some of these models you have to replace the control panel to get the lights to work.I hope this helps Heidi and let me know if you need anymore help.Good luck.
I have a unit that has built in thermostat. When
my ready heater pro115 model numberr115 keeps shutting off
1helpful
91 vw golf will not stay running after 15 minutes
You are losing oil pressure, this means your oil pump is probably out. Don't drive it anymore until you can get that repaired. It's shutting down because it's siezing up. You need the extra power to jump it because the piston rings and wall are sticking together, let it all cool down and the rings contract and loosens up. Allowing the engine to turn.
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
