When monitor is turned on the power light goes from red to flashing yellow instantly. No video or audio. Yello light is on for secs then off for 2 secs...then cycle continously repeats.
Guess I made a blunder newbie mistake...this plasma monitor has to have a AVC (AVC-20) attached to the monitor to be usable.Guess I made a blunder newbie mistake...this plasma monitor has to have a AVC (AVC-20) attached to the monitor to be usable.
You can't post conmments that contain an email address.
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
This TV has both Composite (Red, White and Yellow) plugs and Component (Red, Green, Blue). Either are acceptable solutions, although ideally purchasing an after-market Component Video cable should yield the best possible picture quality.
Sorry I know your model number and its a Power Down trouble with the Scan IC's that are in the unit. You need a tech to look at it and he will most likely find a bad Scan IC and it will need to be replaced. This a is a relatively easy fix for him.
