Motorola Mobility H500 Headset Logo
Posted on Dec 31, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
H500 bluetooth i found a motorola H500 bluetooth headset. i have a samsung a720 phone, and i want to connect the 2 so i can use the headset..duno how..help?
  • Anonymous Jan 17, 2008
    i found a motorola H500 bluetooth headset. i have a samsung phone, and i want to connect the 2 so i can use the headset..duno how..help?
DENNIS MITCHELL
Level 3:
Genius:
  • Master 1,003 Answers
  • Posted on Jan 17, 2008
DENNIS MITCHELL
Master
Level 3:
Genius:
Answers
1003
Questions
0
Helped
367187
Points
2185
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
6helpful
Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
1helpful
HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Motorola H500 and a motorola v3x phone searches and finds headset but won't connect
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
4helpful
3answers
How do i connect H500 to my phone
Hey guys. found it. Go to
www.simoncells.com
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Ed
1helpful
2answers
Problems With Pairing H500 and Motorola V190
4.Select H500once a connection is detected.
Tips:
Samsung a707 won't reconise my H500
Turn the Samsung off, wait 10 seconds, then turn it on and try again. Power cycling the phone really does help sometimes. Let us know if this doesn't help.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
