Honeywell HFD-130 Air Purifier Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Eletrical snapping sound
Making a eletrical snapping sound when turned on. light on the front flickers when snapping
Anonymous
Level 2:
Scholar:
  • Expert 108 Answers
  • Posted on Oct 25, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
108
Questions
0
Helped
55403
Points
258
This is normal....when dust passes through this filter it is "Zapped" that's how the electronic air filter works
  • jitzmaster
    jitzmaster Nov 18, 2022
    it means its clogged.
Red light stays on after cleaning
which model, do you hear arcing or snapping sounds when it's running? Check wires that run along the inside front of the cell, loose, sagging or broken wires will cause this.
The blue light on my Pro Shield ir purifier is staying on
do you hear arcing or snapping sounds when it's powered on? if so check to see where it's coming from, I posted a fix for this in some other posts. check the wires that run along the front of the cell plates, broken loose or sagging wires can cause this
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
2answers
Replace UV light Ecobox unit
Take the filters off and there should be a small tray that you pull out. The bulbs are in the tray
3helpful
2answers
It makes a cracking sound like a bugzapper every couple of min
Yes it does that when dust or something is being purifiedl
2answers
1helpful
Not running quietly
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Top Honeywell Air Purifiers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
